ASR920 QoS Classification
sean_kndy
I am implementing a QoS policy on the ASR920 and I'm having trouble getting it to classify packets on egress.   I tried a very simple class matching EF and a policy to test it and when pinging out the interface with dscp ef set, all the pings fall into class-default instead of my dscp-ef class.  Here is the test config:
class-map match-all dscp-ef
  match dscp ef
policy-map test
  class dscp-ef
    priority percent 5
int te0/0/12
  service instance 888 ethernet
     service-policy output test
ping 172.18.7.105 dscp ef repeat 1000
#sh policy-map interface te0/0/12 service instance 888
TenGigabitEthernet0/0/12: EFP 888
Service-policy output: test
queue stats for all priority classes:
Queueing
queue limit 1966 us/ 122880 bytes
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 0/0
Class-map: dscp-ef (match-all)
0 packets, 0 bytes
5 minute offered rate 0000 bps, drop rate 0000 bps
Match: dscp ef (46)
Priority: 5% (500000 kbps), burst bytes 12500000, b/w exceed drops: 0
Class-map: class-default (match-any)
1000 packets, 122000 bytes
Match: any
queue limit 98 us/ 122880 bytes
(pkts output/bytes output) 1000/122000
sean_kndy
My initial thoughts is that it's due to the fact the service instance is actually a "bridged" configuration and the IP sits on a BDI therefore the service instance may only "see" L2 CoS values. Is this indeed the case? This document seems to indicate that since version 3.5, dscp classification on an EFP is supported : https://www.cisco.com/c/en/us/td/docs/routers/asr920/configuration/guide/qos/qos-guidelines-xe-3-13-asr920-book.html
