08-30-2006 08:37 AM
Need some guidance in things to look for when callers can't be heard well by callcenter agents. I'm thinking the "input gain" but where do you apply this? Dial-peer or T1?
any help is appreciated.
Solved! Go to Solution.
08-30-2006 12:12 PM
08-30-2006 08:49 AM
The "input gain" command is applied to a voice port, for example:
voice-port 0/0/0
input gain 3
Hope this helps. If so, please rate the post.
Brandon
08-30-2006 11:23 AM
It would also work on a DID T1 right? That way all calls inbound would be given the same treatment, right?
08-30-2006 12:12 PM
That's correct. You could have:
voice-port 0/0:23
input gain 3
Brandon
