Calls Accounting and Gatekeeper
andrew-ivanov
Hello!
Can I register the "called number" DNIS when I use gatekeeper accounting and Tacacs+. Tacacs receives
a lot of h323-accounting information but nothing about destination address?
aaa accounting connection h323 start-stop group tacacs+
gw-accounting aaa
acct-template callhistory-detail
gatekeeper
accounting vsa
Following list of the h323 attributes
has been received from the gatekeeper:
h323-gw-id
h323-conf-id
h323-call-origin
h323-call-type
h323-remote-address
h323-disconnect-cause
Thank you.
Best regards.
amitgami
Hi Andrew,
Though I have never used Tacas+ as billing server for VoIP, I guess the CDR records should be same for Radius and Tacacs. The CDR list is very exhaustive in nature and SHOULD contain DNIS by default. There is no special configuration required for sending DNIS in CDR.
Please refer to following documents for CDR reference. It is a good idea to use gateways for obtaining CDRs, since they provide far more fields of information compared to gatekeepers.
http://www.cisco.com/warp/public/cc/so/cuso/sp/sms/acct/caaaf_cg.htm
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_programming_reference_guide09186a00800b5e17.html#xtocid1350
thanks and regards,
Amit.
