calls get disconnect in 20s( diff vendors)
aarizvi213
I am doing natting through pix I am able to through the call but the call get disconnect from B side thats CISCO AS5350. Originator is Quintum( Tenor) A400 and its behind PIX.
plz help me
5 Replies 5
Chester Rieman
Please include more info here. Does audio work in both directions for the 20s when the call is up? What disconnect cause are you seeing? Who is sending the disconnect?
this issue comes only when the originator(Quintum) comes to private IP . We have the Quintum on public and its working fine.
If I used 2500 or 2600 series router with IOS release 12.1 can work , right ????
I think 1700 series routers also support ????
Though i didnt understand u r network scenario fully ,for ur info i have personally experinced ISDN channel disconnecting after 20s in my network.
the reason for the same is due to authentication problem...
regds
prem
