Cisco 7965 question
myersam99
Hello, I'm the new admin for our CUCM ver. 8. Currently, I have a customer with a 7965 phone who would like to have the ringing on his secondary keys turned off. He still wants his primary line to ring just not the other 2. This has to be an easy fix but I just can't find any info on it. Thank you for  your help
Rob Huffman
Hi Christopher,
Go to Device>Phone>Find and find the desired phone. Once you bring it
up click on the actual 2nd and 3rd DN's listed on the top left of the page.
The Ring settings are down towards the bottom of each DN config page;
Change them to either Flash or Disable
Line 2 on Device SEP0022900411F3
Display text for a line appearance is  intended for displaying text such as a name instead of a directory number for  internal calls. If you specify a number, the person receiving a call may not see  the proper identity of the caller.
Required Field
Required Field
Required Field
Applies to this line when any line  on the phone has a call in progress.
Required Field
Cheers!
Rob
"Clocks go slow in a place of work
Minutes drag and the hours jerk"
-The Clash
Rob Huffman
Hi Christopher,
Required Field
Required Field
Required Field
Required Field
Cheers!
Rob
-The Clash
