01-31-2013 04:54 PM
Hello, I'm the new admin for our CUCM ver. 8. Currently, I have a customer with a 7965 phone who would like to have the ringing on his secondary keys turned off. He still wants his primary line to ring just not the other 2. This has to be an easy fix but I just can't find any info on it. Thank you for your help
Solved! Go to Solution.
02-01-2013 11:21 AM
Hi Christopher,
Go to Device>Phone>Find and find the desired phone. Once you bring it
up click on the actual 2nd and 3rd DN's listed on the top left of the page.
The Ring settings are down towards the bottom of each DN config page;
Change them to either Flash or Disable
Cheers!
Rob
"Clocks go slow in a place of work
Minutes drag and the hours jerk"
-The Clash
02-01-2013 11:21 AM
Hi Christopher,
Cheers!
Rob
-The Clash
