Haris,
Your 2821s are capable of running Callmanager Express (CME) for call control. You could also run Callmanager for call control and use the 2821s at branch locations with SRST. To make external calls you will need connectivity with the PSTN - analog lines, T1/E1 PRI, etc.
Hope this helps.
Brandon
