Cube Router IOS Upgrade Problem
kevin.cooke
My SIP router was having some issues with spontaneously rebooting.  I figured I would upgrade the software on the router because there are some various issues with IOS c3900e-universalk9-mz.SPA.151-2.T2.bin.  Other that the rebooting issue the cube was working fine.  I upgraded to c3900e-universalk9-mz.SPA.152-1.T1.bin and I could make calls out and receive calls in as long as it was going directly to a phone or a hunt group, but if a call was made to a callhandler and transfered to a phone the was one way audio.  The Cisco phone could hear but the remote user could not hear him.  I reverted back to the old software and everything is working good again.  Any suggestions?
burleyman
Level 8
Level 8
Can you post the config.
version 15.1
service password-encryption
hostname MY_CUBE01
boot-start-marker
boot system flash c3900e-universalk9-mz.SPA.151-2.T2.bin
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication login default group tacacs+ enable
aaa authentication enable default group tacacs+ enable
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
no ipv6 cef
ip source-route
ip cef
ip domain name rlcarriers.com
ip name-server 128.10.1.5
crypto pki trustpoint TP-self-signed-545534262
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-545534262
revocation-check none
crypto pki certificate chain TP-self-signed-545534262
certificate self-signed 01
  30820252 308201BB A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 35343535 33343236 32301E17 0D313130 37323831 38353831
  335A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3534 35353334
  32363230 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  A08A383C 9B36CD7C 4E6AA29D E1DEA7B3 BC75847D 138F8D62 4729FBE9 9F01F615
  67BCED19 D3C5DFB7 0929E1AC 29A9A21C 9CF2A99C A45EDD63 302B2FF8 F86C2F7F
  90B95160 05643F78 F1892A2C C7FDF04B 01F98F93 B0DC9CB6 39E5A315 1F99B91C
  45385035 37A1382D 142E850B FCC9D125 AF3906A0 11D3F53E E5DA08FD 455ADA5B
  02030100 01A37C30 7A300F06 03551D13 0101FF04 05300301 01FF3027 0603551D
  11042030 1E821C57 494C5F43 525F4355 42453031 2E726C63 61727269 6572732E
  636F6D30 1F060355 1D230418 30168014 90F5746F 649486BC 135A188B 7286A643
  3F7D61EF 301D0603 551D0E04 16041490 F5746F64 9486BC13 5A188B72 86A6433F
  7D61EF30 0D06092A 864886F7 0D010104 05000381 810050F6 3D08B3D8 21B3FDC6
  AC82E4DC D0D93A3A ABCB0482 B916FF0F 3282AEC3 2091B738 78A635EA 1AFAC040
  CCBF0C9D 5C96F8B9 1868E705 DEA7254D 1D9648D1 685504A4 7147F5CC 67BABC94
  07BC2372 EAB23909 488FC3B5 47D8477E BDACF51F 1810F6B7 CA5D20BE 41C816F4
  2184627E 205D2CC4 6B6856FE A88C66DB 2464C35D 8D28
        quit
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
ip address trusted list
  ipv4 172.30.235.0 255.255.255.0
  ipv4 10.60.200.0 255.255.255.0
  ipv4 10.61.200.0 255.255.255.0
  ipv4 10.60.0.0 255.255.0.0
  ipv4 10.75.0.0 255.255.0.0
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
  early-offer forced
  midcall-signaling passthru
voice class codec 1
codec preference 1 g729r8
codec preference 7 g711ulaw
codec preference 8 g711alaw
voice class codec 2
voice translation-rule 9
rule 2 /^9\(.*\)/ /\1/
voice translation-rule 740
rule 1 /.*/ /740XXXXXXX/
voice translation-rule 937
rule 1 /.*/ /937XXXXXXX/
voice translation-profile 740
translate called 9
translate redirect-called 740
voice translation-profile 937
translate called 9
translate redirect-called 937
hw-module pvdm 0/0
redundancy
ip ssh version 2
interface GigabitEthernet0/0
ip address 10.60.200.31 255.255.255.0
ip virtual-reassembly in
load-interval 30
duplex auto
speed auto
ip address 10.60.70.5 255.255.255.0
load-interval 600
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/3
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.60.70.1
ip route 172.30.235.0 255.255.255.0 10.60.70.1
ip tacacs source-interface GigabitEthernet0/0
nls resp-timeout 1
cpd cr-id 1
control-plane
sccp local GigabitEthernet0/0
sccp ccm 10.60.200.35 identifier 2 priority 2 version 7.0
sccp ccm 10.61.200.25 identifier 5 priority 1 version 7.0
sccp
sccp ccm group 10
bind interface GigabitEthernet0/0
associate ccm 2 priority 1
associate ccm 5 priority 2
associate profile 1 register MTP00077dfbd100
dspfarm profile 1 transcode
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 120
associate application SCCP
dial-peer voice 200 voip
description INBOUND G729 from CM to VB
session protocol sipv2
incoming called-number 9T
voice-class codec 1
no voice-class sip early-offer forced
dtmf-relay rtp-nte
dial-peer voice 201 voip
description Inbound 729 from VB to CM
session target sip-server
incoming called-number 937.......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 101 voip
description OUTBOUND G729 Voice SIP calls to CM
destination-pattern 937.......
session target ipv4:10.60.200.35
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 102 voip
description OUTBOUND G729 Voice 911 SIP calls to VB
destination-pattern 911
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 203 voip
incoming called-number 740.......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 103 voip
destination-pattern 740.......
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 300 voip
description OUTBOUND G729 Voice SIP calls to VB
translation-profile outgoing 937
destination-pattern 9T
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 301 voip
destination-pattern 91937.......
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 302 voip
translation-profile outgoing 740
destination-pattern 91740.......
voice-class codec 1
dtmf-relay rtp-nte
sip-ua
retry invite 2
retry bye 2
retry cancel 2
sip-server ipv4:172.30.235.49:5303
g729-annexb override
gatekeeper
shutdown
If you made no config changes then when you update to the new IOS rev try this....I needed to do this and it seemed to work.
config t
no sccp
sccp
exit
That did the trick for me. I am not an expert so there could be something else at play here as well but I do know I did that an it worked.
