Double Answer
ychuan
Is there any command similar for ISDN that have the same function for R2 Digital (Double Answer)??? I'm trying to block few end user to use the collect call service.
regards
ebreniz
Level 6
Level 6
Can the Incoming Call Preauthentication block collect calls users?? Have you ever tried? (do you recommend any configuration). I need something that can make polarity inversion on the PRI/ISDN E1 trunk, because my country collect call rules are a little bit different
