03-10-2008 10:10 AM
What is the pros and cros between
EtherChannel
and
stack
if I want to link up two or more L3 switches (e.g. CAT3750)
rdgs
Solved! Go to Solution.
03-11-2008 07:25 AM
Hi, if one switch fails, the surviving ones should keep configuration.
03-10-2008 12:11 PM
When available, you should always use stack, like in the 3750 that gives you a 32 Gbps connection and makes the switch appears like a single one.
03-11-2008 06:57 AM
I stack the two switches, e.g. switch A and switch B. They stack to each other and treat it as single big switch.
If the switch A (or switch B) is down, can I access the switch?
If yes, how about the config?
e.g.
I config switch A with Vlan 2, 3, 5 and 7 for first 24 ports.
I config switch B with Vlan 3, 7, 10, 15 for the next 24 ports.
Do they keep itself config?.
rdgs
03-11-2008 07:25 AM
