FAX--Store and Forward
Chuan Liu
I have configured store and forward fax on one of my 3845 gateways (ios C3845-ADVIPSERVICESK9-M) :
fax receive called-subscriber $d$
fax interface-type fax-mail
mta send server A.B.C.D (ip address of the mail server)
mta send with-subject both
mta send mail-from hostname akl-core01.turnstone.net.nz
mta send mail-from username fax-mail
application
service faxmail_onramp flash:app_faxmail_onramp.2.0.1.3.tcl
service fax_detect flash:app_fax_detect.2.1.2.2.tcl
dial-peer voice 139770089 pots
information-type fax
incoming called-number 39770089
direct-inward-dial
dial-peer voice 239770089 mmoip
service fax_on_vfc_onramp_app out-bound
destination-pattern 39770089
session target mailto:39770089@fax.com
image encoding MH
image resolution super-fine
ISDN PRA is the connection to PSTN. Debug isdn q931 is as follows:
409726: Feb 28 11:03:35.059: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8 callref = 0x1F70
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18383
Preferred, Channel 3
Calling Party Number i = 0x2183, '21856588'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '39770089'
Plan:ISDN, Type:Subscriber(local)
High Layer Compat i = 0x9181
Sending Complete
409727: Feb 28 11:03:35.071: ISDN Se0/3/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x9F70
Channel ID i = 0xA98383
Exclusive, Channel 3
409728: Feb 28 11:03:35.075: ISDN Se0/3/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x9F70
Cause i = 0x8083 - No route to destination
409729: Feb 28 11:03:35.151: ISDN Se0/3/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x1F70
409730: Feb 28 11:03:35.155: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x9F70
I can telnet to the server on port 25 from this router. Why did I get a 'No route to destination' message? How to solve the problem?
p.s. One other router has exactly the semilar configuration and working fine.
Thanks.
10 Replies 10
Zin.Karzazi
Level 5
Level 5
Please post the output from "show dial-peer voice summary". Also remove the "infomation-type fax" under your pots dial peer.
Hi Zin,
I tried removing the "information-type fax" command. No luck. Here is the summary: I removed the ip addresses.
sh dial-peer voi su
dial-peer hunt 0
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT
10 pots up up .T 0 up 0/3/0:15
39770- voip up up 3977009. 0 syst ipv4:
09
39770- voip up up 39770076 0 syst ipv4:
076
39770- voip up up 39770077 0 syst ipv4:
077
39770- voip up up 39770078 0 syst ipv4:
078
39770- voip up up 39770079 0 syst ipv4:
079
39770- voip up up 39770084 0 syst ipv4:
084
39684- voip up up 3968463. 0 syst ipv4:
63
39680- voip up up 3968002. 0 syst ipv4:
02
13977- voip up up 3977008. 1 syst ipv4:
008
13977- voip up up 39770075 3 syst ipv4:
0075
23977- voip up up 39770075 2 syst ipv4:
0075
39612- voip up up 3961299. 1 syst ipv4:
29
39770- pots down down 0 down 0/3/0:15
080
23977- voip up up 39770080 1 syst ipv4:
0078
13977- pots up up 0 down
0089
23977- mmoip up up 39770089 0
0089
Thanks.
Your Pots dial-peer is down, assign a port to it (ie port 0/3/0)
Hi, where I can find this app_fax_detect.2.1.2.2.tcl file?
hi, Now I have the tcl file, but whit this configuration dont work the fax to mail;
application
service fax_on flash:faxmail_onramp.tcl
mta send server 192.168.0.246 port 25
mta send subject "Servicio de Fax AEC.S.A."
mta send with-subject $s$
mta send origin-prefix "AEC.S.A."
mta send postmaster pepito@midominio.com.co
mta send mail-from hostname cisco.midominio.com.co
mta send mail-from username $s$
dial-peer voice 12 pots
description --------------FAX
service fax_on
incoming called-number 3279659
direct-inward-dial
port 1/5:D
dial-peer voice 11 mmoip
destination-pattern 3279659
session target mailto:pepito@midominio.com.co
this is the show call history voice brief
F18 : 108377 152975920ms.93875 +-1 +40 pid:10 Answer 17420719
dur 00:00:00 tx:0/0 rx:0/0 1 (unassigned number (1))
Telephony 1/5:D (108377) [1/5.24] tx:0/0/0ms None noise:0dBm acom:0dBm
long duration call detected:n long dur callduration :n/a timestamp:n/a
thanks a lot.
You may need the fax detect tcl. Here is my working config:
application
service fax_detect app_fax_detect.2.1.2.2.tcl
You can use "show call hist fax" to chech the fax infor.
Regards.
Hi, thanks a lot, now is working, but in some many call, give me this error
show call fax history voice brief
1F6 : 209228 238019430ms.178911 +1000 +21150 pid:105 Originate crearpais@aecsa.com.co
dur 00:00:20 tx:7250/0 rx:0/0 6F :0 (protocol error (111):)
MMOIP 192.168.0.246 AcceptedMime:0 DiscardedMime:0
1F6 : 209205 238003890ms.178912 +10 +36730 pid:305 Answer 56644538
dur 00:00:36 tx:13/168 rx:47/940 6F :6F (protocol error (111):protocol error (111): Receive communication)
Telephony 1/4:D (209205) [1/4.17] tx:0/0/0ms 9600 noise:-83dBm acom:57dBm
If the problem happens randomly, I would say the configs are OK, and then focus on the digital interface and packet loss.
Rgds.
It's also possible to get protocol errors when you're using T37 if there is a fax-layer problem that fails. This can happen if we send fax tones and we're ready for page data, but no page data comes. If any of the number of fax timers expire, we will disconnect with 111 protocol error.
