Frame Relay and as5350
farshid_sh
Dear Experts,
we got a 2811 framrelay hub ,which also runs VOFR ,since the device is not fully compatible with our PBX we decided to replace it with an As5350 ,but unfortunatley the as5350 does not support VOFR , is there any way to configure Vofr on as5350 with ios upgrade or any other way?
if not , is it possible to configure a 3640 router as the hub router wich runs VOFR ,and also configure the 3640 as a gatekeeper to route the calls to as5350 for termination and vice versa ?
all suggestions are welcomed,
Farshid.sh
paolo bevilacqua
Hi, as you noted the 5350 doesn't support VoFR. You can only terminate VoFR on other models, having the 3640 doing GK would not help, because GK is for VoIP only.
Many thanks to your reply ,I think the only way left is to switch to VoIP.
Best Regards,
