Gatekeeper registration and call diversion
happykiran
Hi all, I have implemented the following configurations in my system.
When I do this, all the calls are going to gatekeeper without matching any prefix or any other parameter. Apart from the dial-peer listed here, I have got three more dial-peers from where I want to send the calls to different gateways.
Question is, How do I divert only specific traffic, to GK and the rest of the traffic should pass through other dial-peers as normal ?
1) voice rtp send-recv
2) call rsvp-sync
3) interface FastEthernet0
h323-gateway voip interface
h323-gateway voip id gk1 ipaddr x.x.x.x 1719
h323-gateway voip id gk2 ipaddr x.x.x.x 1719
h323-gateway voip h323-id zeko6
4) dial-peer voice 1 voip
destination-pattern 00T
session target ras
dtmf-relay
codec g729br8
no vad
Kiran
vkapoor5
Level 5
Level 5
Hi Saeed,
As far as my knowledge goes, there is no such software for Imate.
anthonylee
Kiran,
There's another option for you.
You have to configure the GK correctly on the GW,
verify the succesfull registration and then
you can combine the dial-peers as usual as per example below:
dial-peer voice 2 voip
incoming called-number .
destination-pattern .T
voice-class codec 100
session target ras <- going to configured GK
dtmf-relay h245-alphanumeric
fax-relay ecm disable
fax rate 9600
fax nsf 000000
fax protocol t38 ls-redundancy 1 hs-redundancy 1 fallback none
dial-peer voice 13 voip
preference 4
destination-pattern 072.......
session target ipv4:217.19.0.22 <- specific GW1
dial-peer voice 14 voip
preference 5
destination-pattern 074.......
session target ipv4:217.19.0.16 <- specific GW2
etc...
Hope this will help you.
