03-15-2005 03:55 PM
Hi guys,
How to use port 1718 and 1719 in gateway and gatekeeper?
When I configure gateway and gatekeepter, I got the both default port 1719. Is it right? Should I change them? They are UDP or TCP port? What are their functions?
GW-A1#
interface Ethernet0/0
ip address 172.22.1.1 255.255.255.0
h323-gateway voip interface
h323-gateway voip id GK-A ipaddr 172.22.1.3 1719
h323-gateway voip h323-id GW-A1@abc.com
h323-gateway voip tech-prefix 1#
GK-A#
gatekeeper
zone local GK-A abc.com
zone remote GK-B abc.com 172.22.2.3 1719
zone prefix GK-B 214.......
zone prefix GK-A 512.......
gw-type-prefix 1#* default-technology
arq reject-unknown-prefix
no shutdown
Thanks a lot.
yytellmey
03-16-2005 03:17 PM
1- ras signalling port to communicate between gk and remote gk is 1719 default. (inter zone ras)
2-ras signalling port to communicate between gw and local gk is 1718 default. (intra zone ras)
3-both 1718 and 1719 ras signalling ports are tcp ports.
4- you can change default ports by using:
on gateways:
h323-gateway voip id yyyy ipaddr x.x.x.x [port number]
on gatekeepers:
zone remote yyyy zzzz.com x.x.x.x [port number]
5- changing default ports is not a "must",but can be done, and also i advise not to change unless you really need it.
6-these ports are used for ras signalling for both gk-to-gk and gw-to-gk.
03-16-2005 04:17 PM
I have a maybe related question....
how do i prevent an H323 GW,AS5300 w 12.3(13),
from continually trying to register with some GK it finds on the net....
Mar 16 20:16:50 GMT: %CCH323-2-GTWY_REGSTR_FAILED: Gateway PRBppd failed to register with Gatekeeper tbhudnws.TOABAJAHUD.LOCAL even after 2 retries
Mar 16 20:17:06 GMT: %CCH323-2-GTWY_REGSTR_FAILED: Gateway PRBppd failed to register with Gatekeeper tbhudnws.TOABAJAHUD.LOCAL even after 2 retries
voipgw#
Rich
03-16-2005 05:57 PM
RAS Gatekeeper Discovery:
There are two processes by which H.323 terminals/gateways discover their zone gatekeepers:
Unicast Discovery (manual method) - Uses UDP port 1718. In this process, endpoints are configured with the gatekeeper IP address and can attempt registration immediately. The gatekeeper replies with a gatekeeper confirm (GCF) or gatekeeper rejection (GRJ) message.
Multicast Discovery (auto-discovery) - Uses UDP multicast address 224.0.1.41. Auto discovery enables an endpoint to discover its gatekeeper through a multicast message. Because endpoints do not have to be statically configured for gatekeepers, this method has less administrative overhead. A gatekeeper replies with a GCF message or remains silent. A gatekeeper can be configured to respond only to certain subnets.
If a gatekeeper is not available, the gateway periodically attempts to rediscover a gatekeeper. If a gateway discovers the gatekeeper has gone off-line, it stops accepting new calls and attempts to rediscover a gatekeeper. Active calls are not affected.
03-16-2005 05:40 PM
03-16-2005 06:00 PM
Sorry, made a mistake. RAS uses udp 1718 and 1719, not tcp!!!
