Gets Fax/Modem Tone When Making Outbound calls on VOIP.
starcommsadmin
We'vesetup a VoIP connectivity on our gateway/router for Outbound & Inbound calls,we receive IB calls sucessfully bt Outbound calls gives a fax/Modem tone,the recepient complains can't see the call bt can see call simulations from my router
Despite having configured PI value to 8 on d Dial peer # POTS and Dial Peer # VoIP,still is still failing,wireshark traces done,depicts calls are termintaing from Switch to Gateway. Pls any help!!!
Please, add more info.
What is your gateway? Can you add the config and debugs? Can you add the whireshark trace? Can you add a net scheme? Do you use tcl scripts?
Regards.
