How to change Default Sip port 5060 to --> 5062
mrutedo
wong34539
Level 6
Level 6
Are you looking for changing this on the Proxy server or on the Router? If it is on the Router and are looking for feature like PAM, then see http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca7c8.html
t.daniel
Did you find an answer to this?
For originating just add the port number after column in session target ipv4:x.y.z.k:5062
For incoming...not sure, but NAT even is the same box could work.
