%HPI-3-CODEC_NOT_LOADED
seheng
Could someone assist me on this problem?
I am using Cisco 2610XM router with IOS flash:c2600-ipvoice-mz.123-1a.bin.
After the router have been up for sometime then the VIC-2FXS hang, no dial tone. then I will received any error massage %HPI-3-CODEC_NOT_LOADED.
Normally after reset the router then everything is back to normal
is the any way to solve this problem beside resetting the router?
Seheng
spremkumar
Level 9
Level 9
Hi ther
the ios u hv mentioned has been defered for the below reasons :
DDTS No(s):
CSCeb49708
Headline: NRP2 hangs while trying to establish PPPoEoE session
CSCec06547
Headline: seeing MIPC timer error after boot and PIF-3-GIGE_DISABLE_GMAC_ERROR
CSCin50865
Headline: Called part hangs during the H.323 call
may be u r hitting the last bug so do upgrade the ios to other version.
regds
prem
Hi Prem,
Which version of IOS you can recommand?
thanks alot
Sim
i would suggest to chek this link and choose the ios as per your requirement..
http://cisco.com/cgi-bin/Software/Iosplanner/Planner-tool/iosplanner.cgi?get_crypto=&data_from=&hardware_name=2610XM-2611XM&software_name=&release_name=&majorRel=12.3&state=:HW&type=
Note:CCO login is reqd to access this page..
regds
prem
