VoIP Tandem
arraman
I am looking for a sample configuration where a router acts as a tandem for a voip call. Below is the scenario:
(1111)phone --- (FXS)Router ------ Router (3600) ----- Router (2600) (FXS) ---Phone (2222)
For example if the "1111" user dials 2222, the call should be forwarded to 3600 voip router, which checks for the destination number if it is "2222" then it should forward the call to Router#2 2600.
Can anyone provide be some pointers for a sample configuration on the dial-peers that are to be configured on 3600 tandem router.
thanks
Arun
spremkumar
Level 9
Level 9
i havent seen this kind of scenario though the dialed numbers will be intaken at the (FXS) Router itself.
Then thts the one which will forward to the remote peer matching the Dial peer with session target ip.
so i dont think the 3600 will come into picture ,ofcourse it will act as a facilitator between both the (FXS) Router by forwarding the packets between them.
suggest to search in technology support (in cisco.com) u may find one not sure though..
regds
prem
