HSI without gatekeeper
i.fouraki
can we use HSI without a gatekeeper, but have it communicate with an H.323 gateway directly? If yes, how do we need to configure the HSI for that?
Yanna
Dear ebreniz,
I know that HSI works with PGW, but I am refering to the H323 part of the network. Is a gatekeeper required?
regards,
Y.
A gatekeeper is required, so that the HSI knows what IP address to direct the call to.
RAS transactions do not take up much CPU, so even a small gatekeeper can be sufficient for use with a HSI.
