Integration of a sip trunk on cisco 2610xm
ciscosniper7
here is my problem .... I have a sip trunks line (data and voice) from the operator .... sip trunk cable is plugged into trunk port of router (Zyxel) ....I made a filter for the lines....first for data (Internet), second for  voice (VoIP) ... data it works very well.        Now i want to install the other line (voIP) in cisco router (CME) ... Plz help Me .        http://data.imagup.com/7/1120478359.png
Call Manager Express (CME) is not supported in 2610 platform. Even CME 4.x is supported from 2800, 3800 series onwards..  Refer this below link for platform support.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme42spc.htm
Its pretty simple to install CME if you have any 2800 series router.  Thanks.  Pl rate if info is useful.
Further to update you, Pl find the platform support for all the CME versions.. Thanks
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_device_support_tables_list.html.
