03-07-2007 02:53 AM
I have 2811 ruter installed with FXS card. I have a FXO card but since its not supported on 2811, i therefore installed it in 3620. How will i interconnect these routers having FXS card on one router and FXO card on the other??
03-07-2007 04:01 AM
I am not quite sure, what you would like to achieve with this setup, but you can use a "normal" analog telephone cable with RJ11 connectors.
FXS will be the PBX side and FXO will be the telephone side of the connection.
Hope this helps!
Regards, Martin
03-11-2007 05:37 PM
Connect them with ethernet and confgure the appropriate dial-peers. Generally speaking, for a given destination-pattern, the dial-peer will of pots type on one router, and voip on the other.
You can use either H.323 or SIP for this.
