IOS for Cisco1760
mhostbaek
Group,
I've got a Cisco1760, and when inserting a VWIC-2MFT-G703 to either slot2 or slot3 it is not recognized. What is the minimum IOS version needed ?
Or could it be a problem with the router ?
Thank you,
mhostbaek
Actually the version is irrelevant (as long as the IOS release is > 12.2(4)YB)
However, am I correct in asuming that the IPVOICE feature set is required ?
/mich
Check this one. It has a table with the suppoprted IOS across platforms.
http://cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800b6e0f.shtml
Yes you would need IP VOICE or IP PLUS feature set as you need to run voice.
GS
