VWIC-1MFT-G703 support for ISDN PRI signalling
senthil
Hi there
I have cisco 1760-V gateway with 2 fxs modules... Now the client wants to use
this gateway as a test E1 PRI setup in their Lab with just 4 to 6 channels
support. The client has an existing VWIC-1MFT-G703 module.
And my question here is
- does VWIC-G703 module support ISDN PRI Signalling ??
- Can I have limited (default) DSPs to packetize the voice calls fm few channels in PRI alone ??
TIA
Senthil
sriram.g
1. I hope this link answers your question.
http://cisco.com/en/US/partner/products/hw/routers/ps274/products_tech_note09186a00800b6e0f.shtml
2. You could create pri-groups and the number of timeslots you would assign in that would be used for voice and the remaining for data. The DSP's would be used accordingly serving the number of channels allocated for voice.
GS
