IP address changing at PGW IP address changing at PGW IP address changing
tareqrebhi
Dear all,
i need to change the IP address for my PGW2200 is that straight forward or i need to remove all PGW's configuration to do that rebuild the configuration again?
if you please can give any example.
thank you
hadbou
Level 5
Level 5
If you suspect an SSH security-policy error, such as a mismatch between the security policy defined for a component at deployment and its actual security policy, you can do one of two things:
"Check SSH-related alarms in the Event Browser. You can see SSH-related alarms, such as a mismatched security policy or an incorrect password, for the BAMS, Cisco PGW, and HSI server, in the Event Browser. These are Warning alarms. For a description of Cisco PGW 2200, the BAMS, and HSI alarms caused by login failures related to SSH problems.
no dear,
i need to move PGW from sabnet network to other subnet....
now i am asking if i need to change IP address for PGW it is straight forward?
if yes? just change IP address in related command.
If NO? can explain what the errors.
BR,
tareq
