09-16-2009 08:04 AM
I've CUCM 7.02 with H323 GW for one cisco 2811 with 2 FXO ports, and i cannot do a outgoing call.
The call is placed and after 12 seconds the call disconect with " Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=47)"
Pedro Silva
09-16-2009 11:15 AM
Take "debug vpm signal" with "term mon". Also send voice-port configuration.
09-25-2009 06:54 AM
09-25-2009 07:05 AM
Under voice port configure
no battery-reversal
09-25-2009 07:16 AM
With the command "no battery-reversa" have the same problem.
incomig evertihng ok but outgoing after 12 seconds the call is off (but i don't have any audio in outgoing call)
sh voice call status
CallID CID ccVdb Port DSP/Ch Called # Codec Dial-peers
0x347 5AB 0x479D23F0 0/1/1 0/1:1 *0924915542 None 1/924915542
09-25-2009 07:22 AM
Configure:
no soft-offhook
and take debug vpm again. No need to use attachments.
09-25-2009 07:27 AM
voice-port 0/1/1
no battery-reversal
cptone PT
connection plar opx 8001801
impedance complex2
caller-id enable
VPM SIGNAL:
Sep 25 15:26:18.792: htsp_timer_stop3 htsp_setup_req
Sep 25 15:26:18.796: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
Sep 25 15:26:18.796: [0/1/1] set signal state = 0xC timestamp = 0
Sep 25 15:26:18.796: htsp_timer - 1300 msec
Sep 25 15:26:20.096: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER]fxols_wait_dial_timer htsp_dial
Sep 25 15:26:21.948: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_DONE, E_DSP_DIALING_DONE]fxols_wait_dial_done htsp_alert
Sep 25 15:26:21.948: htsp_timer - 350 msec
Sep 25 15:26:21.948: htsp_call_bridged invoked
Sep 25 15:26:22.300: htsp_process_event: [0/1/1, FXOLS_WAIT_CUT_THRU, E_HTSP_EVENT_TIMER]fxols_handle_cut_thru
Sep 25 15:26:22.300: htsp_timer_stop
Sep 25 15:26:28.773: htsp_process_event: [0/1/1, FXOLS_OFFHOOK, E_DSP_SIG_0110]
Sep 25 15:26:28.773: htsp_timer_stop2
Sep 25 15:26:34.041: htsp_timer_stop3
Sep 25 15:26:34.041: htsp_process_event: [0/1/1, FXOLS_OFFHOOK, E_HTSP_RELEASE_REQ]fxols_offhook_release
Sep 25 15:26:34.041: htsp_timer_stop2
Sep 25 15:26:34.041: [0/1/1] set signal state = 0x4 timestamp = 0
Sep 25 15:26:34.041: htsp_timer - 2000 msec
Sep 25 15:26:34.317: htsp_process_event: [0/1/1, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
Sep 25 15:26:36.041: htsp_process_event: [0/1/1, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
Sep 25 15:26:36.041: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_DSP_SIG_0100]
09-25-2009 08:07 AM
Can you dial using a nromal telephone ?
Can you try "destination-pattern 9", check you have dialtone a dial after that.
09-25-2009 08:09 AM
i will try monday. Tnks for your help
09-28-2009 01:41 AM
09-28-2009 01:51 AM
Check that there is no number manipulation for the ip phones.
Beside that I would not know what to suggest.
09-28-2009 01:55 AM
i don't have any digit manipulation.
Any idea??
09-28-2009 03:18 AM
Which exact IOS are you using ?
09-28-2009 05:33 AM
System image file is "flash:c2800nm-advipservicesk9-mz.124-15.T9.bin"
10-05-2009 03:43 AM
My problem is solved, my costumer have put a ASA in tranparent mode between CM and the gateway. I remove the
inspect H323 and everthig is working fine.
Pedro Silva
