Megacom T1 help
jmccartney1
We are bringing up new long distance T1's in the next week from AT&T using Megacom and they are non-ISDN T1's. Does anyone have a configuration or know what setting are needed for this? We are running CUCM 4.2 (yes I know --OLD) in a MGCP environment.
I built the endpoint T1 under the gateway parameters and we have a good link on our physical gateways, any help is appreciated.
John
paolo bevilacqua
Megacom is ISDN PRI. If using H.323 (best choice), configure "isdn nsf-service megacom"
