10-25-2004 09:24 AM
Anyone know if you can configure a 2620XM using MGCP and Megacom service. We have one configured but can only get inbound LD to work. I same a table somewhere on CCO that showed support for Megacom on a 2620 H.323 but not MGCP.
10-29-2004 01:07 PM
You have to configure Network Specific Facilities (NSF) on an ISDN PRI for outgoing
calls configured as voice calls, use the isdn nsf-service command in interface
For more information check the below link
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fdial_r/drfd.htm#15574
Also you need to config
map-class dialer sdnplan
dialer outgoing sdn
dialer voice-call
Add map-class to your dialer config
07-15-2005 10:58 AM
If your using MGCP, not H.323, you can set the NSF on the route pattern in Callmanager. Since the D channel terminated on the CCM. If H.323 then set it on the serial interface of the PRI.
