Need help on basic setup
pipsadmin
New to Cisco VoIP but been doing SIP for several years now. Here is what I have and what I need.
Cisco 2801 with c2801-advipservicesk9-mz.124-20.T1.
Fa0/0
ip 10.10.10.1/24
Fa0/1
ip 10.98.5.247/23
I have a PC with Xlite softphone
10.10.10.2
Extention 2002
I got the Xlite to register to the router, but trying to route all external calls to a specific IP 10.98.5.245 which is a Acme SBC.
Here is my setup. Can someone tell me what I'm doing wrong?
Router#sh run
Building configuration...
Current configuration : 3965 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$DiN8$kyxjpdY/DaGEuqzTFrqlr1
no aaa new-model
memory-size iomem 20
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice service voip
allow-connections sip to sip
redirect ip2ip
sip
registrar server
no call service stop
voice register global
mode cme
source-address 10.10.10.1 port 5060
max-dn 30
max-pool 20
authenticate register
voice register dn 1
number 2002
allow watch
name xlite
label test
mwi
voice register pool 1
id mac 0002.B330.B04A
number 1 dn 1
presence call-list
dtmf-relay rtp-nte sip-notify
username 2002 password 2002
codec g711ulaw
voice-card 0
username cisco privilege 15 secret 5 $1$2ssP$haAS0QsYZMyhfSp61rqKl.
archive
log config
hidekeys
interface FastEthernet0/0
ip address 10.10.10.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.98.5.247 255.255.254.0
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.98.4.1
no ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip http path flash:/html
control-plane
dial-peer voice 2000 voip
description "outbound"
destination-pattern 16137330000
b2bua
session protocol sipv2
session target ipv4:10.98.5.245
dtmf-relay rtp-nte
codec g711ulaw
no vad
sip-ua
credentials username 2001 password 7 115B495546 realm none
authentication username 2002 password 7 1357474259
telephony-service
max-ephones 20
max-dn 20
ip source-address 10.10.10.1 port 5060
max-conferences 8 gain -6
web admin system name pipsadmin password pipsadm
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 2
number 2002
label 2002
description 2002
name 2002
hold-alert 30 originator
ephone 1
device-security-mode none
line con 0
line aux 0
line vty 0 4
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
Brandon Buffin
Currently, dial peer 2000 will only send calls to 16137330000 out the SIP trunk. If you are not using an access code such as 9 and you want to send all calls to the SIP provider, you can use "destination-pattern .T".
Hope this helps.
Brandon
Thanks !
WHere can I get more info on the patterns?
Take a look at the following link.
http://www.cisco.com/en/US/docs/ios/12_2/voice/configuration/guide/vvfpeers.html#wp1258752
Hope this helps. If so, please rate the post.
Brandon
