08-09-2005 01:35 AM
IOS 12.3(4)T4 on 3745.
While Telnet, SSH or console into router we see no debug output even after turning Terminal monitor, we can only see the show outputs, etc. While consoled into the 3745 we see nothing there is No prompt or any messages at all.
We tried replacing the console cable and placed it on different PCs or laptop still no go. I was thinking of reloading the router tomorrow night, but want to check if anyone has come across this problem. It was all working in the past without any changes.
Is there like a command i need to add, etc. But i am 100% sure its all good on the 3745.
Cheers!
-Yavuz
08-09-2005 05:47 AM
Try 'logging console'
'sh logg' will show what is currently being logged, look for this line to see what is being logged to the console:
Console logging: level debugging, 49 messages logged, xml disabled, filtering disabled
Hope this helps
08-22-2005 10:50 PM
opps... ignore.
