Hello everybody, I have a problem to access remotely to CCM 4.2(39. Using the web browers on my laptop the java screen does not give the login, it just shows a green screen.
If I use the Remote Desktop, it gives the msg that the Server has not remote access activite, I actived on the Server Routing and Remote Access.
I have following scenario: a switch, the MCS 7815 I2 with OS 2000.4.3a upgraded to 2000.4.3aSR5 and CallManager 4.2(3), the gateway 2821 and mi laptop.
If I work on the server everything work just fine.
ANY HELP WILL BE REALLY APRECIATE
THANK YOU
