No ringback and no call stablisment from one party side
djtoro
I have a live voice/data network in star topology. The network has up eigth routers but my problem is with one site where the data traffic is working but the voice traffic no working at one direction. The star center is CARACAS and two branch are MARIPOSA and VALERA. The calls from MARIPOSA to CARACAS and from CARACAS to MARIPOSA work very well but the calls from CARACAS to VALERA no working and from VALERA to CARACAS yes!!!
Why??. I don't know what happened!!.
The show running-config and show version of the three routers is attached.
djtoro
The calls from MARIPOSA to VALERA and from VALERA to MARIPOSA is working fine. The routing is running.
Thansk very much.
Daniel Toro
Try removing the forward-digits 2 from the dial peers in VALERA.
GS
I removed that command but no working. In fact, I used the same MARIPOSA IOS in VALERA and nothing.
Thanks for your suggestion.
