Calls disconnect after error %CALL_CONTROL-6-NUMBERING_TYPE_NO_MATCH
darren.frowen
If anyone could help or advise me on the following problem.
We use Cisco7206VXR for our voice gateway with PA-VXC-2TE1.
A customer is arrempting to originate calls over IP via a Qiuintum DXC2030. Rhe problem is that the calls is abruptly terminated without being able to establish the Telphony call leg.
I turn on "debug voice ccapi inout" and the following error is seen:
Error Message
Cisco.com says reference this error:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123sup/123sems/123semv1/emgc6msf.htm#1034779
Error Message
%CALL_CONTROL-6-NUMBERING_TYPE_NO_MATCH : The called number numbering type did not matchThe event for the callid [dec] is being discarded.\n
Explanation: The event points to a session application that no longer exists. The event is being discarded.
Recommended Action: This message is informational. No action is required.
Can someone please help me to know why this is happening and how I may overcome this!
Anyone help would be greatly appreciated!
Kindest Regards
Darren Frowen
Senior Network Engineer
Satellite Media Services.
sriram.g
Can you paste the necessary config, calling and called number and a small ASCII diagram.
GS
Hi GS,
Thankyou for your time and update. Then Called and calling numbers are as follows:
Called: 00441788523003
Calling: 12345676
Please see attached "show run" and Network diagram.
Your help in this matter would be gratley appreciated.
Kindest Regards
Darren Frowen
