PAP2T Installation - there is no green light or tone on Line1 or 2
cisco7878
Hello, I am new to VoIP, just got a brand new PAP2T, and need some help starting up.
I have ordered it as PAP2T-NA to use with sipgate, but cannot find "NA" anywhere on the packaging or the product. Is there a way to tell by S/N or MAC address if this is actually "NA"?
When I installed the unit it only has green lights for Power and Internet, but there is no green light or tone on Line1 or 2. I cannot proceed with configuration without dial tone. Any suggestions?
Message was edited by: David Abayev I have researched more and it appears that there is specific parameter. When you login into Linksys PAP2T web interface the System tab has Product Information section. If the last parameter shows " Customization:  Open“ then the PAP2T is NA or "unlocked" unit. As for the lack of green light or dial tone on Line1, this is not a problem. These are not required. To get the IP address via IVR Menu on the phone you do not need the dial tone or green light, just  enter four starts **** and continue as specified in the manual. After PAP2T has actually registered with VoIP service provider the green light on Line1 will lit and you will have the dial tone.
Chester Rieman
The NA designation on a PAP-2T shows that it is not preconfigured for a particular carrier (vonage, etc).
I'm not sure how you can confirm that it's actually an NA device.
Check the settings under
http://:8080/Voice_adminPage.htm
Hope this helps,
Chester
