Bookmark
Subscribe
981
PGW call trace commnads
amitsalunkhe21
Dear All
I'm new in PGW fields & i want to knwo different commands which we can use to trace call for different issue. Here i want to aks commnd like snoop,tethreal.
Please let us know command with examples. Also we can run this command on which directory of PGW or we can run any where in PGW and where we need to save those trace logs.
i want commands which i can use & read by own,  no intervention like to send cisco support team & then they will analyze.
Please help me
Thanks--
Amit--
Here is a document which helps you take a Call trace in PGW. Login to the PGW MML >    using "mgcusr"  and follow these
steps to take the PGW Call trace
https://supportforums.cisco.com/docs/DOC-12528
Here is the commands to collect the PGW Platform related information and you do it by logging it as "root" user.
1. Unix version (uname –a)
2. Memory (prtconf | grep Memory , uname)
3. Processor details (psrinfo –v)
4. Free disk space (df –k)
5. Interface statistics (ifconfig -a, netstat – irn)
6. Patch information (pkginfo | grep CSCO)
Thanks.  Try the above document and if f you need further more information on PGW commands, pl revert.
