PRI Faxing issues over Wireless network
MarkMonteleone
Is there a way that I can properly troubleshoot if I have a LEC issue or dropped packets from a 2421 or ATA?
I have issues terminating many faxes from 2421's. I almost never get ATA to send fax properly. This is,I think that config is right as sometimes they go through, sometimes they don't. For the longest time I thought it was dropped packets across the WLAN, but know I see that even on great links with no bandwidth being consumed, their are certain numbers that always fail! Thought it may be the PRIs interaction with the gateway/ccm or remote 2421....
paolo bevilacqua
is the T1 controller clean of slips on the gw?
Have you configured the ATA for fax accordingly to the many docs on the matter ?
