problem interconnecting AS5300 with PBX
tirmatovt
Hi!
I have a following setup: local PBX connected through PRI ISDN with AS5300. AS5300 emulates network side and delivers all calls via IP to other AS5350 PSTN gateway. Calls made from PSTN are happily delivered via ip network to AS5300 and then to PBX. But calls from PBX always fail. I turned on 'isdn q931' debug and see following complaints on cisco:
*Jan 1 00:24:53.783: ISDN Se0:15 Q931: RX <- SETUP pd = 8 callref = 0x7DE3
Bearer Capability i = 0x9090A3
Standard = CCITT
Transer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x81, '1130000'
Plan:ISDN, Type:Unknown
*Jan 1 00:24:53.787: ISDN Se0:15 **ERROR**: call_incoming: Received a call id 0xD with a bad bearercap from 1130000 on b channe
l 1
*Jan 1 00:24:53.791: ISDN Se0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xFDE3
Cause i = 0x82D8 - Incompatible destination
my cisco config is pretty straightforward:
contr e1 0
pri-group timeslots 1-31
int se0:15
isdn switch-type primary-net5
isdn protocol-emulate network
dial-peer voice 10 pots
destination-pattern 1130000
direct-inward-dial
port 0:d
dial-peer voice 1 voip
destination-pattern .......
session target ipv4:xx.yy.zz.nn
Any hints will be greatly appreciated!
goranselthofer
You didn't show all your voice-related config, but put this under intse0:15
isdn incoming-voice modem
and also, you can put under voice-port configuration:
bearer-cap Speech
let me know about the results... :)
