Problem with ISDN redirecting number
Emily Sharrard
Hi Community.
I have three numbers that I requested to have forwarded to another number via the Telco.  Two of them work fine, one does not.  The two that are working fine are linked to Extension Mobility Profiles.  The problematic number is pointing to a Call Tree in unity.  When I dial the DID for the call tree 571.XXX.XXXX I get to the call tree successfully.  When I dial 703.XXX.XXXX which is pointed to 571.XXX.XXXX I get another unity Greeting.  Below I am including the activity I see on the gateway when I dial 703.XXX.XXXX.  Please note there are two seperate gateways.
To me this seems like a Telco problem.  I just want to make sure I am not missing anything form the Call Manager side.
GW2
       Progress Ind i = 0x8188 - In-band info or appropriate now available
Mar 11 19:35:12 UTC: ISDN Se0/1/0:23 Q931: RX <- CONNECT pd = 8  callref = 0x916E
Mar 11 19:35:12 UTC: ISDN Se0/1/0:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x116E
Mar 11 19:35:18 UTC: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x1039
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98397
                Exclusive, Channel 23
        Display i = 'Sharrard, Emily'
        Calling Party Number i = 0x0081, '571.MyExtension'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '1703Number that is being Forwarded'
Mar 11 19:35:18 UTC: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x9039
Mar 11 19:35:18 UTC: ISDN Se0/0/0:23 Q931: RX <- ALERTING pd = 8  callref = 0x9039
        Progress Ind i = 0x8088 - In-band info or appropriate now available
Mar 11 19:35:18 UTC: ISDN Se0/0/0:23 Q931: RX <- CONNECT pd = 8  callref = 0x9039
Mar 11 19:35:18 UTC: ISDN Se0/0/0:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x1039
GW1
Mar 11 19:34:59 UTC: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x0634
Mar 11 19:34:59 UTC: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8634
Mar 11 19:35:18 UTC: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x1C3E
                Standard = CCITT
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Facility i = 0x9F8B0100A10F02010E06072A8648CE1500040A0100
                Protocol Profile =  Networking Extensions
                0xA10F02010E06072A8648CE1500040A0100
                Component = Invoke component
                        Invoke Id = 14
                        Operation = InformationFollowing (calling_name)
                                Name information in subsequent FACILITY message
        Calling Party Number i = 0x0080, '571MyExtension'
        Called Party Number i = 0xA1, '571Extension to Which the call is being forwarded'
                Plan:ISDN, Type:National
        Redirecting Number i = '!', 0x008F, '703Number that is forwarded to the number above'
Mar 11 19:35:18 UTC: ISDN Se0/0/0:23 Q931: RX <- FACILITY pd = 8  callref = 0x1C3E
        Facility i = 0x9F8B0100A11702010F020100800F4245434854454C2020202020202020
                0xA11702010F020100800F4245434854454C2020202020202020
                        Invoke Id = 15
                        Operation = CallingName
                                Name Presentation Allowed Extended
                                Name = BECHTEL
Mar 11 19:35:18 UTC: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x9C3E
Mar 11 19:35:18 UTC: ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8  callref = 0x9C3E
Mar 11 19:35:18 UTC: ISDN Se0/0/0:23 Q931: TX -> CONNECT pd = 8  callref = 0x9C3E
        Display i = 'VoiceMail Srv 1'
Manish Prasad
Level 5
Level 5
Yes certainly this is a Telco issue , you need to talk with them.
There is one more solution to it by using translation on voice gateway. Convert called number 703.xxxxxx to DID of the call tree 571.XXX.XXXX before sending to CUCM.
Manish
Emily Sharrard
HI Manish,
Thank you for your input.  We were able to get it resolved.  It was a combination of Telco and Call Routing on our part.  Because this particular line was routing to a call tree in Cisco Unity Connection, that was part of the issue.  To resolve it we added a "Forwarded Routing Rule" in unity under 'Call Routing'.
I hope this answer can help others,
Emily
