QoS for Voip
marman
Please see the output below. As you can see the amount of packets is 11840, and these are marked however in the queue the amount of packets matched is just 179. On my other policies these two figures are the same....could this be a cause of dropping voice calls??
Service-policy output: PIPER-POLICY
Class-map: voice-traffic (match-all)
11840 packets, 781453 bytes
30 second offered rate 22000 bps, drop rate 0 bp
Match: access-group 102
QoS Set
precedence 5
Packets marked 11840
Queueing
Strict Priority
Output Queue: Conversation 72
Bandwidth 100 (kbps) Burst 20000 (Bytes)
(pkts matched/bytes matched) 179/39466
(total drops/bytes drops) 0/0
r.samuelpeter
If you are using CBWFQ , QoS will come in to effect in the event of congestion. Although you may mark all the packets but you may not match all the marked packets if there is no congestion in egress interface.
Rob
Thanks for the response, we are using LLQ on CBWFQ, please see the class-maps and poliy we have.
class-map match-any decnet
match access-group 111
class-map match-all voice-traffic
match access-group 102
class-map match-all RADAR
match access-group 110
class-map match-all voice-signalling
match access-group 103
class-map match-any VCC
match access-group 112
policy-map PIPER-POLICY
class voice-traffic
set ip precedence 5
priority 150 20000
class voice-signalling
set ip precedence 5
bandwidth 8
class decnet
police 32000 6000 12000 conform-action transmit exceed-action transmit viol
ate-action drop
class VCC
set ip precedence 4
priority 256 72000
class class-default
fair-queue
CAn you see anything that may be causing an issue - thanks
marman,
Place your 'marking' policy, where you set ip prec 5, on an ingress interface (service-policy input ...)instead of an egress. And place your queuing policy on egress interfaces (service-policy output ...).
Assuming your access-list 102 is good, you can still match on the same criteria. However, this way, traffic coming into the router is marked, and when it exits, it hits the egress policy and will be priority queued.
However, the best way to do this is match your access-list for the marking policy, and match precedence for queueing.
If I were to guess why you're PQing any ip prec 5 (dscp ef) traffic, I'd guess it is because this router is a Gateway as well. And by default, it will generate rtp traffic with ef/ip-prec 5 set. Such traffic will be priority queued.
Another protocol that Cisco automatically marks prec 5 is DLSW.
Let me know if this helps.
nchidamb
" 11840 packets " were classified and put into 'voice-traffic' queue. ' Pkts matched 179 ' means that due to congestion 179 packets were queued. So, the less you see in ' pkts matched ' is better for the voice. Based on your brief desription I would say look for other things if voice calls are dropping.
-Nat
