QoS output need explanation
satishmothukri
Hi ,
Can anybody explain below outputs taken from 3750 switch on which QoS is configured for priortizing Voice traffic.
sw1#sh mls qos maps dscp-output-q
Dscp-outputq-threshold map:
     d1 :d2    0     1     2     3     4     5     6     7     8     9
      0 :    04-03 04-03 04-03 04-03 04-03 04-03 04-03 04-03 04-01 04-02
      1 :    04-02 04-02 04-02 04-02 04-02 04-02 03-03 03-03 03-03 03-03
      2 :    03-03 03-03 03-03 03-03 02-03 02-03 02-03 02-03 02-03 02-03
      3 :    02-03 02-03 03-03 03-03 03-03 03-03 03-03 03-03 03-03 03-03
      4 :    01-03 01-03 01-03 01-03 01-03 01-03 01-03 01-03 02-03 02-03
      5 :    02-03 02-03 02-03 02-03 02-03 02-03 02-03 02-03 02-03 02-03
      6 :    02-03 02-03 02-03 02-03
sw1#sh mls qos maps cos-output-q
   Cos-outputq-threshold map:
              cos:  0   1   2   3   4   5   6   7
  queue-threshold: 4-3 4-2 3-3 2-3 3-3 1-3 2-3 2-3
sw1#sh mls qos interface g1/0/1 queueing
GigabitEthernet1/0/1
Egress Priority Queue : enabled
Shaped queue weights (absolute) :  25 0 0 0
Shared queue weights  :  25 25 25 25
The port bandwidth limit : 100  (Operational Bandwidth:100.0)
The port is mapped to qset : 1
sw1#sh run int g1/0/1
interface GigabitEthernet1/0/1
description <<connection to wr1>>
switchport mode trunk
priority-queue out
mls qos trust dscp
ip dhcp snooping trust
end
sw1#show platform port-asic stats drop gigabitEthernet 1/0/1
  Interface Gi1/0/1 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
     Weight 2 Frames 6292      -----> reason for drops
    Queue 1
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 4
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 5
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 6
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 7
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
sw1#show platform port-asic stats enqueue gigabitEthernet 1/0/1
  Interface Gi1/0/1 TxQueue Enqueue Statistics
    Queue 0
        Weight 0 Frames 2
        Weight 1 Frames 0
        Weight 2 Frames 20548539
    Queue 1
        Weight 0 Frames 121832    ----->  why so many frames in queue 1 ..what is the significance
        Weight 1 Frames 743121
        Weight 2 Frames 6612555    --- > are these frames are in queue to get forwarded..Noticing frames in Queue 3 also
Queue 2
        Weight 0 Frames 0
        Weight 1 Frames 0
        Weight 2 Frames 14728
   Queue 3
        Weight 0 Frames 7849
        Weight 1 Frames 6344
        Weight 2 Frames 58654525
    Queue 4
        Weight 0 Frames 0
        Weight 1 Frames 0
        Weight 2 Frames 0
    Queue 5
        Weight 0 Frames 0
        Weight 1 Frames 0
        Weight 2 Frames 0
    Queue 6
        Weight 0 Frames 0
        Weight 1 Frames 0
        Weight 2 Frames 0
    Queue 7
        Weight 0 Frames 0
        Weight 1 Frames 0
        Weight 2 Frames 0
Thanks ,
M S K
Thanks , M S K
0 Replies 0
