07-11-2005 01:11 PM
Hi.
I have a problem with ISDN QSIG.
My setup is:
A---PBX-A----2651A----FR----2651B----PBX-B---B
When A calls to B, I see the call arriving in 2651A but the call doesn´t arrive in 2651B. I enabled debug voice cca inout and I don´t see anything.
When B calls to A , the phone A rings but I don´t ear nothing and the call is finished.
My config is the follow:
2651A
no network-clock-participate slot 1
no network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 E1 0/1
voice-card 0
dspfarm
ip cef
isdn switch-type primary-qsig
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
controller E1 0/1
framing NO-CRC4
line-termination 75-ohm
pri-group timeslots 1-8,16
interface Serial0/1:15
no ip address
no logging event link-status
isdn overlap-receiving
isdn protocol-emulate network
isdn incoming-voice voice
isdn T310 4000
isdn send-alerting
no cdp enable
voice-port 0/1:15
bearer-cap Speech
dial-peer voice 1 pots
incoming called-number .
destination-pattern 10
direct-inward-dial
port 0/1:15
dial-peer voice 2 voip
destination-pattern 20....
session target ipv4:1.1.1.1
dtmf-relay cisco-rtp
2651B
voice-card 0
dspfarm
ip cef
voice rtp send-recv
controller E1 0/1
framing NO-CRC4
no ip address
isdn T310 4000
isdn send-alerting
no cdp enable
voice-port 0/1:15
bearer-cap Speech
direct-inward-dial
port 0/1:15
destination-pattern 10....
session target ipv4:1.1.1.2
What is wrong??
I think that the problem is relative to ISDN signalization.
Thanks.
07-11-2005 05:33 PM
What digits need to be sent to the PBX?
POTS dial peers by default do not forward the digits that match, so in your case the first 2 digits will not be sent. You can change this with a forward-digits X or forward-digits all under the peer.
A debug ISDN Q931 will show you what is being sent.
The fact the call does not go fast busy suggest the E1 D channel is up and talking, but you should see layer 2 multiple frames established if you show isdn status
07-12-2005 03:49 AM
07-12-2005 08:05 AM
The ISDN Q931 signalling between the PBXs and the routers look OK, but all the H225 call signalling messages are not making it from the terminating router to the originating router. It would be interesting to see the output from debug h225 event for both A & B.
What version IOS are you running?
07-12-2005 10:00 AM
Look debug in 2651A
Jul 12 02:57:29.695: Changing to new event: CONNECT
h323chan_chn_connect: connecting to 83C815A4:1720
Jul 12 02:57:29.695: h323chan_gw_conn: Created socket fd=2
Jul 12 02:57:29.695: h323chan_gw_conn: connect in progress on fd=2h323chan_chn_connect: using fd=2, owner_data(ccb) 0x83
C77FD0
changing from NONE state to CONNECTING state
Jul 12 02:57:29.735: h323chan_chn_process_read_socket: fd=2 of type CONNECT_PENDING has data
Jul 12 02:57:29.735: Changing to new event: CONNECTED
changing from CONNECTING state to CONNECTED state
Jul 12 02:57:29.735: compose_TunnelledSignallingMessage_cisco Tunnelled Content:
IAM,
PRN,isdn*,,QSIG*,
USI,rate,c,s,c,1
USI,lay1,alaw
TMR,00
CPN,00,,4,201003
CGN,00,,4,y,1,6604
CPC,09
FCI,,,,,,,y,
GCI,85003e36f1b711d980a1c0b0562607dd
Jul 12 02:57:29.739: The length of message content is:[166]
Hex representation of the SETUP TPKT to send.: 080200350504038090A36C060980363630347007893233313030307E02520520800600089
14A00042800B500001240013C0501000085003E36F1B711D980A1C0B0562607DD00CD1D82000700C8B653522B4C11008500DAF6F1B711D980A3C0B05
62607DD3402130000000C2013800B05000100C8B653524081801E400000060401004C2013801215000100C8B65352408000C8B653524081800100010
001800180010010A8018081170140B5000012810FE0010000010480FE04038090A31803A983881C2291AA068001008201008B0100A11402020100060
42B0C09008008485120414E4452451E0281836C06098036363034700789323331303030A1953101
803201811CB19E010003677464000000A649414D2C0D0A50524E2C6973646E2A2C2C515349472A2C0D0A5553492C726174652C632C732C632C310D0A
5553492C6C6179312C616C61770D0A544D522C30300D0A43504E2C30302C2C342C3233313030300D0A43474E2C30302C2C342C792C312C363630340D
0A4350432C30390D0A4643492C2C2C2C2C2C2C792C0D0A4743492C38353030336533366631623731316439383061316330623035363236303764640D
0A0D0A06800600040000000380AE02046774640180A649414D2C0D0A50524E2C6973646E2A2C2C515349472A2C0D0A5553492C726174652C632C732C
632C310D0A5553492C6C6179312C616C
h225SetupRequest: Q.931 SETUP sent from fd=2
Jul 12 02:57:29.747: h323chan_chn_process_read_socket: fd=2 of type CONNECTED has data
Jul 12 02:57:29.747: h323chan_recvdata: No Data on fd=2
PROCESS_READ: FAILED/NOT COMPLETE,rc 10, fd=2
Jul 12 02:57:44.748: compose_TunnelledSignallingMessage_ciscoNo tunnelled content.
Hex representation of the RELEASE COMPLETE TPKT to send.: h225TerminateRequest: Q.931 RELEASE COMPLETE sent from fd=2. C
all state changed to [Null].
Jul 12 02:57:44.752: h323chan_close: TCP connection from fd=2 closed
In 2651B I didn´t see any message. Nothing arrives.
In 2651A, I use c2600-ipvoice-mz.123-6a.bin and in 2651B I use c2600-ipvoice-mz.123-4.T6.bin.
Thanks.
07-12-2005 01:11 PM
I am assuming you can ping fully between the 2 routers? Are there any firewalls or access-lists between the 2?
If you can ping, and are sure there is no filtering occurring I would load the A router with the same IOS T code as the B.
07-13-2005 11:27 AM
David,
The ISP did a big mistake. I´ve checked a lot frame-relay parameters with ISP and it not configured correctly.
The problem was QoS and fragmentation in backbone.
Thanks a lot.
