Hi all,
I have cisco 2610 with 4 FXS connected to PBX.
I want to have the same destination pattern on all 4 FXS with preference settings.
When user for example dial 700228 call will be through to PBX and then recording message appears and user press desired extension.
At the same time if user dial same number 700228 he will assign to another FXS port and then PBX asked that user for the desired extension and call will be completed.
attached below is the my configuration.
Please suggest me if this solution works
voice-port 1/0/0
output attenuation 6
echo-cancel coverage 32
cptone JP
timeouts interdigit 5
voice-port 1/0/1
cptone JP
voice-port 1/1/0
cptone JP
voice-port 1/1/1
cptone JP
dial-peer voice 777777 voip
incoming called-number +700...
fax-rate 9600
ip precedence 5
no vad
dial-peer voice 700001 pots
destination-pattern +00228
port 1/0/0
dial-peer voice 700002 pots
preference 1
port 1/0/1
dial-peer voice 700003 pots
preference 2
port 1/1/0
dial-peer voice 700004 pots
preference 3
port 1/1/1
dial-peer voice 800000 voip
destination-pattern +8T
fax-rate 9600
ip precedence 5
no vad
session target ipv4:192.168.1.1
Waiting for your guidance
