Siemens Switch EWSD signaling problem with AS5300
daeakins
I have an AS5300 which I am trying to connect to a Siemens EWSD switch using ISDN PRI. The controller comes up. When I do show isdn status everything looks good. But when we try to place a call some of the digits are missing and I get an error message of Invaild information element contents.
Please find the attachment of the debug I ran:
Here is the config on the AS 5300
interface Serial0:23
no ip address
no logging event link-status
isdn switch-type primary-ni
isdn incoming-voice modem
no cdp enable
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 10 voip
destination-pattern 1..........
progress_ind setup enable 3
voice-class codec 99
session target ipv4:66.88.14.254
dtmf-relay h245-signal h245-alphanumeric
ip qos dscp cs5 media
I believe it is a D-channel problem on the switch end. Any suggestions? Thanks. I have searched Cisco's site to no avail.
dragos.stroescu
Your configuration is OK from the ISDN perspective.
What I can see in the debugs&config is that the AS5300 is receiving a call to '3828345' for which there is no dial peer configured (no route!!) with an appropriate "destination-pattern".
The AS sends back the "Requested circuit/channel not available" cause code for disconnect.
You can add a dial-peer pointing to a correct destination (voip or pots) configured with "destination-pattern 3......" for example.
You can check if the router is able to handle a specific destination by using:
CCM-EXPRESS#sh dialplan number 002233755
Macro Exp.: 002233755
No match, result=1
CCM-EXPRESS#sh dialplan number 60
Macro Exp.: 60
VoiceEncapPeer10
peer type = voice, information type = voice,
description = `',
tag = 10, destination-pattern = `60',
answer-address = `', preference=0,
output missing
dragos.stroescu
No match, result=1
Macro Exp.: 60
VoiceEncapPeer10
description = `',
output missing
Dragos
I try to work around with my as5800 the following call flow :
customer---->telco house---->as5800------>Telco house
<232....> <160221>
This I want to do by sharing same E1 PRI for both inbound and outbound dial-peer.The config I did for dial-peer is :
translation-rule 1
rule 0 2055 160221
dial-peer voice 2171 pots
incoming called number 217232....
dial-peer voice 2172 pots
destination-pattern 2055
translate-outgoing called 1
port 1/0/2:d
I dont have any voice feature card in as5800 and presently it used for only internet dial up access and no voice application.
The information I got from cisco site is :
"call hairpinning without the need of a Voice Feature Card (and its digital signal processor) is available only on the Cisco AS5800"
Till now no success for me.
Pls help.
thanks and regds,
Prasanna
daeakins
Thanks, I knew that the dial pattern wasn't correct. I was waiting for the carrier to fix it on his side. But I have never seen it come across with the modem error message. I have seen it come across with no matching dial-peer. As soon as the carrier fixed it on his side it worked beautifully. Thanks very much
daeakins
