Signaling E&M-FGB not supported in 3845
jonathan.perez
I have the following problem:
When I try to configurate the interface E1 "VWIC2-2MFT-T1/E1" with this command:
"ds0-group 0 timeslots 1-15,17-31 type e&m-fgb"
router don´t received it.
GW-1(config-controller)# ds0-group 0 timeslots 1-15,17-31 type ?
  e&m-delay-dial       E & M Delay Dial
  e&m-fgd              E & M Type II FGD
  e&m-immediate-start  E & M Immediate Start
  e&m-lmr              E & M land mobil radio
  e&m-melcas-delay     MEL CAS (CEPT) E & M Delay Start
  e&m-melcas-immed     MEL CAS (CEPT) E & M Immediate Start
  e&m-melcas-wink      MEL CAS (CEPT) E & M Wink Start
  e&m-wink-start       E & M Wink Start
  ext-sig              External Signaling
  fxo-ground-start     FXO Ground Start
  fxo-loop-start       FXO Loop Start
  fxo-melcas           MEL CAS (Mercury) FXO
  fxs-ground-start     FXS Ground Start
  fxs-loop-start       FXS Loop Start
  fxs-melcas           MEL CAS (Mercury) FXS
  none                 Null Signalling for External Call Control
  r2-analog            R2 ITU Q411
  r2-digital           R2 ITU Q421
  r2-pulse             R2 ITU Supplement 7
Im using this IOS:
c3845-advipservicesk9-mz.124-24.T1.bin
Which could be problem?
Jonathan Perez
paolo bevilacqua
Simply that is not supported.
What is your specific need ? *ANI*DNIS* ?
paolo bevilacqua
I need the signaling E&M-FBG because I will migrate from AS5300 with this signaling --> (PBX) to 3845
