SIP OID
sergio.danelli
I am trying to find an OID that keeps track of SIP calls in a voice gateway. Does anyone know of one?
Any suggestions on how to track active calls besides snmp?
paolo bevilacqua
There is specific MIB for SP, the general voip MIBs apply.
Beside SNMP, you can track calls using radius accounting to a server.
There also off-the shelf billing solution that will od everything for you, example stonevoice.
thanks for your reply. Do you know the exact OID for this?
I am using Solarwinds Orion and building a custom MIB poller for this. I just can't find the exact OID.
There is more than one MIB that you can use. Search CCO for "voice call mib".
