SIP-Trunk with Cisco CUBE and LYNC
at
hello,
we should connect a LYNC-Server with a SIP-Provider. Therefore we use a Cisco CUBE 2951.(15.2.3T)
Calls outbound (From LYNC to SIP/PSTN) are ok
Calls inbound (From SIP/PSTN to LYNC) are ok
Calls Forwarded back to SIP/PSTN are not ok  (The call is successfull, that means signaling, rtp  is ok,
but the siganlling numbers in sip-header are not ok)
Detail:
The provider complains : Wrong A-number and no Diversion Header
                                     FROM should contain the number of the forwarder or a Diversion header must be added.
example :
A: +4989-111111 (SIP/PSTN)
B:+49711-123456 (LYNC)
C: +4989-222222 (SIP/PSTN)
B has a Call Forward all to C;
A calls B - B forwards the call to C
The call outgoing contains in the FROM-field <sip:+4989111111@....>
Any tips for configuriation the CUBE (especially with LYNC) ?
regards
alex
paolo bevilacqua
Post config under "voice service voip".
hi,
the config under voice service voip :
voice service voip
ip address trusted list
  ipv4 x.x.x.x
  ipv4 x.x.x.x
mode border-element license capacity 60
allow-connections sip to sip
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  session transport tcp
  header-passing
  error-passthru
  early-offer forced
  midcall-signaling passthru
best regards
alex
configure
voice service voip
no supplementary-service sip moved-temporarily
