02-14-2013 10:26 AM
Hi experts, we use PGW in Italy and it is configured with Q.767 ISUP recommendation. We have an issue with outgoing IAM.
The M bit is always set to 1.
The paragraph C.3.20 titled "Forward Call Indicators" says that the M bit is reserved for national use.
The Italian variant is the following:
bit M : Call diversion restriction indicator
0 = Call diversion not restricted
1 = Call diversion restricted, call to be offered.
With the bit setted to 1 (default for PGW) the call forward service of called party is not honoured.
Is there a way to set this bit to 0?
Regards.
UPDATE: CISCO TAC provided me a fixed file with italian Q767 version.
10-20-2016 07:09 AM
Hi Daniele Giordano,
I´m facing the same problem just now :-( . Do you know if the was a public release of the patch?. Do you conserve that file? Thank you very much
Juan Manuel Munárriz
11-17-2016 10:26 AM
Hi, yes I've the fix but it's customized for italian Q767 version.
Do you use this SS7 variant?
Regards.
11-18-2016 02:24 AM
Thank you for your answer. Yes we are using Q.767 Italian version. It would be great to try the fix :-). For what PGW2200 version was the fix?.
11-18-2016 03:10 AM
The fix is for version 9.8(1).
To install the fix you must stop the service and replace the files, so restart the call service.
Do you use the same version?
Regards.
11-18-2016 03:14 AM
11-19-2016 03:11 AM
Consider that PGW is in EoS/EoL but according to official documentation you can cantact Cisco TAC:
Regards.
