Subnet for data and voice vlan
haluochen9988
When creating a voice and a data vlan on a switch port for an IP phone and a computer which connected to the phone, do the phone and the computer need to be on different subnet or they can be on the same one?
For example, do I have to put the phone on 192.168.1.x/24 while the computer on 192.168.2.x/24, or they both can stay at 192.168.1.x/24?
Thanks.
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Allows you to place an ACL on traffic to/from VoIP subnet.
If subnet is also on a different VLAN, may restrict the number of packets (e.g. broadcast) seen by the VoIP device's NIC.  Also may allow the VoIP device's NIC to filter received packets to just those on its VLAN.
Joseph W. Doherty
Disclaimer
Posting
Phones and data can work on the same subnet/VLAN.
haluochen9988
Hi Joseph,
What is the advantage of putting data and voice on different subnet?
Disclaimer
Posting
Thanks Joseph for the answer.
