TCL Script - disconnecting call with cause 34
brothaluca
I try to develop TCL script that will disconnect call with cause 34 immediatelly when call reaches dial-peer that tcl-script is assigned. To be more detailed: dial-peer that tcl application would be assigned should be outgoing voip dial-peer on Session Border Controller box. Any suggestions?
paolo bevilacqua
Sure, use the "leg disconnect" command and you can specify the cause code.
Thanks for fast answer;) I try with following script:
proc act_Cleanup { } {
leg disconnect leg_all -c34
call close
set fsm(CALL_INIT,ev_any_event) "act_Cleanup same_state"
fsm define fsm CALL_INIT
but my calls are still disconnected with cause 16 ;(
Any suggestions?
Ok, I found the bug: I need to assign service to dial-peer in outbound direction:
service c34 out-bound
Now works great;)
