08-22-2004 05:07 PM
Can someone help, The ATA 188 is not inserting Ring Tone when calling the UK, just get silence untill called party answers. Have tried changing connect mode bit 19 to 1 but this does not work. Anybody able to help?
08-30-2004 12:24 PM
Ringback tone is not heard due to call progress in-band related issues You may like to go through the following document for some troubleshooting tips.
Troubleshooting No Ringback Tone on ISDN-VoIP (H.323) Calls
http://www.cisco.com/en/US/tech/tk652/tk701/technologies_tech_note09186a0080094c33.shtml
02-01-2005 04:16 AM
If you mean the actual phone that is being called isn't ringing, this is due to the cable used to connect to the port on your Cisco device... see this link:
http://www.vonage-forum.com/ftopic1258.html
Aaron
02-02-2005 11:11 AM
pls how can i get my Cisco ATA 188 with software release 3.1 online, i can't figure out where to put my calling account credit in it, can someone help out
07-06-2005 10:48 PM
Hi Terry,
I have the same problem as yours! Have you solved it? If so, could you sheld me some light? Thanks!
Emerson
