VOIP CALLS MONITORING USING MRTG
ra_jeshkalra_2
Can some body tell me whether VOIP H323 calls on a ISDN PRI interface be recorded real time using MRTG from Cisco 3745 VOIP router.
The idea is to see the number of calls connected on ISDN PRI in real time using MRTG.
I have heard about some CISCO MIBS, how can they utilised in the above scenario?
mheusinger
Level 10
Level 10
have a look at the ISDN MIB
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2&submitClicked=true&mibName=ISDN-MIB#contents
The link will open the MIB browser allowing you to search through most Cisco and standard MIBs.
HTH, Martin
